Author Topic: haupauge fb für andere anwendungen (es klapt)  (Read 11297 times)
« on: 04. March 2008, 18:47:03 »
vorwort es ging mir aufn senkel das ich nurr den wmp und die orginal software von haupauge mit der fb bedienen konnte.
dann hab ich mehr oder weniger durch zufall eine irremote.ini im win dir gefunden^^
und nen bisll gespielt^^
so schaut sie aus im moment is noch nicht ganz fertig.
implemntiert wurde winamp und irfanview...
; FGR 02/10/2006 Support firmware V2; 32-bit IR application
; FILEVERSION 2,50,24040,0
; includes support for both Classic black, Silver PVR remote, and new extended Remote
; (extended remote has Music/Videos/Pictures and seperate NAV buttons among others)
; requires ir32.exe, irremote.dll 2.45.22230 or later
; Supports Key Codes 64-127 via RC5 'field' bit
; support latest IR HW on WinTV-USB2, and "IR Blaster" RC5/RC6 receiver
; adds support for retail apps to work with MS MCE "beanbag" Remote on non-MCE systems
; adds support for HCWHID custom interface
[Remote]
RepeatDelay=3
;Beep = 1           ; Sound for MessageBeep() to make for each Remote Keystroke
;PowerDownSound = 0 ; Sound for MessageBeep() to make when powering down
MenuLoad=1       ; use tray as app launcher
; map RC5 System Codes to button "name" lookup table
; Note: 0 (classic remote) conflicts with standard "philips" TV remotes
[SystemCode]
0=HCWClassic
30=HCWPVR2
31=HCWPVR
; "IR Blaster" HW can support RC6; this is for the MS MCE remote table if desired
;0x800f=MSMCE
; This supports using the MCE "Beanbag" remote with retail apps on non-MCE systems
0xffbc=MSMCERCV
0x2040=HCWPVR2
; these tables map actual IR scan codes to button "names" on a per system code basis
; Undefined values get the name "CODExx" by default (mostly for debugging)
; Real buttons on a remote should always get a real button name
; Note: some button "names" can only be generated by certain remotes
; Also, note that seemingly similar buttons may have unique names on different remotes
; This is to allow treating them differently based on the remote, and the
; "paradigm" of how they are used.  For example; on old remotes there is a seperate TV
; button, but no GRNPOWER button.  So, on old remotes we treat TV as on/off, where  on PVR
; remote we use the GoMenu function (or RED as On), and the GRNPOWER as Off.
[HCWClassic]
; need to differentiate old '0' from newer remotes; Old 0 was also labled "pause"
0=OLD0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
12=RADIO
13=MUTE
15=TV
16=VOLUP
17=VOLDOWN
30=RESERVED
32=CHNLUP
33=CHNLDOWN
34=SOURCE
38=MINIMIZE
46=FULLSCREEN
[HCWPVR]
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
46=GREEN
56=YELLOW
11=RED
41=BLUE
12=FUNC
13=MENU
15=MUTE
16=VOLUP
17=VOLDOWN
32=CHNLUP
33=CHNLDOWN
61=GRNPOWER
31=BACK
37=OK
59=GO
60=FULLSCREEN
55=REC
54=STOP
48=PAUSE
53=PLAY
50=REWIND
52=FASTFWD
30=SKIPFWD
36=SKIPREV
[HCWPVR2]
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
46=GREEN
56=YELLOW
11=RED
41=BLUE
13=MENU
15=MUTE
16=VOLUP
17=VOLDOWN
32=CHNLUP
33=CHNLDOWN
61=GRNPOWER
31=BACK
37=OK
59=GO
55=REC
54=STOP
48=PAUSE
53=PLAY
50=REWIND
52=FASTFWD
30=SKIPFWD
36=SKIPREV
;new to hcwpvr2
12=RADIO
28=TVNEW
24=VIDEOS
25=MUSIC
26=PICTURES
27=GUIDE
22=NAVLEFT
23=NAVRIGHT
20=NAVUP
21=NAVDOWN
10=TEXT
14=SUBCC
18=CHNLPREV
[MSMCE]
12=GRNPOWER
23=REC
25=STOP
24=PAUSE
22=PLAY
21=REWIND
20=FASTFWD
26=SKIPFWD
27=REPLAY
13=MCEJEWEL
35=BACK
38=GUIDE
32=NAVLEFT
33=NAVRIGHT
30=NAVUP
31=NAVDOWN
34=OK
37=LIVETV
74=VIDEOS
71=MUSIC
73=PICTURES
80=RADIO
70=TV
14=MUTE
16=VOLUP
17=VOLDOWN
18=CHNLUP
19=CHNLDOWN
36=DVDMENU
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
10=CLEAR
11=ENTER
78=PRINT
72=RECORDEDTV
28=CAPSLOCK
29=MCE29
128=MCE128
129=MCE129
; by default the MS Beanbag sends most keys as either keyboard chars or APP_COMMANDS already
; so we only handle the "special" buttons
[MSMCERCV]
12=GRNPOWER
;23=REC
;25=STOP
;24=PAUSE
;22=PLAY
;21=REWIND
;20=FASTFWD
;26=SKIPFWD
;27=REPLAY
13=MCEJEWEL
;35=BACK
38=GUIDE
;32=NAVLEFT
;33=NAVRIGHT
;30=NAVUP
;31=NAVDOWN
;34=OK
37=LIVETV
74=VIDEOS
71=MUSIC
73=PICTURES
80=RADIO
70=TV
;14=MUTE
;16=VOLUP
;17=VOLDOWN
;18=CHNLUP
;19=CHNLDOWN
36=DVDMENU
;0=0
;1=1
;2=2
;3=3
;4=4
;5=5
;6=6
;7=7
;8=8
;9=9
;10=CLEAR
;11=ENTER
78=PRINT
72=RECORDEDTV
28=CAPSLOCK
29=MCE29
126=MCE128
127=MCE129
90=TEXT
91=RED
92=GREEN
93=YELLOW
94=BLUE
; First item in this section IS always the default app if no others found
[Applications]
Default=
WinTV Remote=
;Win/TV+=
;Win/TV=
WinTV32=
WinTV32(1)=
WinTV32(2)=
WinTV32(3)=
WinTV32(4)=
WinTV32(5)=
WinTV32(8)=
WinTV32(9)=
WinTV32(10)=
WinTV32(11)=
WinTV32(12)=
FullScreen=
PVRFullScreen=
*task*=
;*suspend*=
EPGdemo=
VTplus=
Create and Receive=
Debug.txt=
hcwGDisplayWindow=
hcwGo=
Windows Media Player=
ActiveMovie Window=
Dell Media=
PowerCinema=
ShowShifter - The Home Entertainment Manager=
Winamp=
IrfanView=
[Default]
OLD0=
0=
1=
2=
3=
4=
5=
6=
7=
8=
9=
TV={close(radio.exe)}{sleep(750)}{run(wintv2k.exe)}
TVNEW={close(radio.exe)}{sleep(750)}{run(wintv2k.exe)}
SOURCE={switch(*task*)}{shift}{tab}
MINIMIZE=
FULLSCREEN={alt}{space}x
RESERVED=
; close current active window; disabled for now
;GRNPOWER={sys(0xF060)}
;GUIDE={run(epgdemo.exe)}
GO={gomenu()}{findwnd(,WinTV Remote)}{fgnwnd()}
;GO={run(hcwGo\hcwGo.exe)}
MENU={switch(*task*)}{shift}{tab}
;;these 3 buttons are not offical yet
RED={close(radio.exe)}{sleep(750)}{run(wintv2k.exe)}
GREEN={close(wintv2k.exe)}{sleep(750)}{run(radio.exe)}
;;YELLOW={close(radio.exe)}{sleep(750)}{run(..\vtplus\vtplus32.exe)}
TEXT={close(radio.exe)}{sleep(750)}{run(..\vtplus\vtplus32.exe)}
;;default mappings to drive apps that use APPCOMMANDS on Win2000/XP
MUTE={app(0x80000)}
CHNLUP={app(0x330000)}
CHNLDOWN={app(0x340000)}
VOLUP={app(0xa0000)}
VOLDOWN={app(0x90000)}
REC={app(0x300000)}
STOP={app(0xd0000)}
PAUSE={app(0x2f0000)}
PLAY={app(0x2e0000)}
REWIND={app(0x320000)}
FASTFWD={app(0x310000)}
SKIPFWD={app(0xb0000)}
SKIPREV={app(0xc0000)}
; built-in IR gomenu()
[WinTV Remote]
OK={enter}
VOLUP={tab}
VOLDOWN={shift}{tab}
BACK={sys(0xF060)}
CHNLUP={shift}{tab}
CHNLDOWN={tab}
FULLSCREEN={enter}
SOURCE={enter}
OK={enter}
GO={enter}
GRNPOWER={esc}
NAVUP={shift}{tab}
NAVDOWN={tab}
NAVLEFT={shift}{tab}
NAVRIGHT={tab}
; external 10ft UI
[hcwGo]
CHNLUP={UP}
CHNLDOWN={DOWN}
VOLUP={RIGHT}
VOLDOWN={LEFT}
FULLSCREEN={enter}
OK={enter}
BACK={BACK}
GRNPOWER={esc}
GO={space}
GREEN={F2}
RED={F3}
NAVUP={UP}
NAVDOWN={DOWN}
NAVLEFT={LEFT}
NAVRIGHT={RIGHT}
[hcwGDisplayWindow]
CHNLUP={home}
CHNLDOWN={end}
VOLUP={pgdn}
VOLDOWN={pgup}
FULLSCREEN={enter}
OK={enter}
BACK={BACK}
GRNPOWER={esc}
GO={space}
NAVUP={home}
NAVDOWN={end}
NAVLEFT={pgup}
NAVRIGHT={pgdn}
[ShowShifter - The Home Entertainment Manager]
GRNPOWER={alt}{f4}{sleep(1000)}6{enter}
CHNLUP={ctrl}{up}
CHNLDOWN={ctrl}{down}
VOLUP={ctrl}{right}
VOLDOWN={ctrl}{left}
OK={enter}
MENU={ctrl}g
MUTE={alt}m
BACK={esc}
GO={ctrl}{home}
CHNLPREV={ctrl}g
REC={alt}r
STOP={alt}s
PAUSE={alt}a
PLAY={alt}p
REWIND={alt}{shift}f
FASTFWD={alt}f
SKIPFWD={alt}n
SKIPREV={alt}{shift}n
TVNEW={ctrl}{f1}
VIDEOS={ctrl}{f2}
MUSIC={ctrl}{f4}
RADIO={ctrl}{f6}
GUIDE={ctrl}{f7}
PICTURES={ctrl}{f8}
NAVUP={up}
NAVDOWN={down}
NAVLEFT={left}
NAVRIGHT={right}
SUBCC={ctrl}n
TEXT={ctrl}n
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
RED={F6}
GREEN={Ctrl}-
YELLOW={Ctrl}+
[Winamp]
0={shift}V
1={ctrl}t
2=x
3=v
4={left}
5=c
6={right}
7={ctrl}d
8=s
9={alt}3
CHNLUP=b
CHNLDOWN=z
VOLUP={up}
VOLDOWN={down}
RADIO={close(winamp.exe)}{run(C:\Programme\WinTV\radio.exe)}
TV=
MINIMIZE={sys(0xF020)}
MUTE=c
FULLSCREEN={ctrl}{shift}k
RESERVED={sys(0xF060)}
[IrfanView]
0={esc}
1={ctrl}f
2={up}
3=f
4={left}
5={ctrl}h
6={right}
7={ctrl}m
8={down}
9={ctrl}l
CHNLUP={space}
CHNLDOWN={backspace}
VOLUP=+
VOLDOWN=-
RADIO={close(i_view32.exe)}{run(radio.exe)}
TV={close(i_view32.exe)}{run(C:\Programme\WinTV\hcw.exe /WINTV2KNC)}
MUTE=m
FULLSCREEN={ctrl}w
RESERVED={alt}{f4}
[PowerCinema]
OLD0=0
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
NAVLEFT={LEFT}
NAVRIGHT={RIGHT}
NAVUP={UP}
NAVDOWN={DOWN}
OK={enter}
BACK={esc}
;BACK={BACK}
; old remote, not supportted
SOURCE=
MINIMIZE=
FULLSCREEN=
RESERVED=
GO={alt}{home}
MENU=
;;mappings to use APPCOMMANDS
MUTE={app(0x80000)}
REC={app(0x300000)}
STOP={app(0xd0000)}
;Teletext Group
RED={ctrl}z
GREEN={ctrl}q
YELLOW={ctrl}x
BLUE={ctrl}c
TEXT={ctrl}{shift}t
; try pushing both CC and Subtitle, hopefully one is valid
SUBCC={ctrl}{shift}s{ctrl}{shift}t
TV={ctrl}t
TVNEW={ctrl}t
RADIO={ctrl}a
MUSIC={ctrl}m
VIDEOS={ctrl}e
PICTURES={ctrl}i
GUIDE={ctrl}g
CHNLPREV={ctrl}l
[Dell Media]
OLD0=0
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
NAVLEFT={LEFT}
NAVRIGHT={RIGHT}
NAVUP={UP}
NAVDOWN={DOWN}
OK={enter}
BACK={esc}
;BACK={BACK}
SOURCE=
MINIMIZE=
FULLSCREEN=
RESERVED=
GO={alt}{home}
MENU=
MUTE={app(0x80000)}
REC={app(0x300000)}
STOP={app(0xd0000)}
;Teletext Group
RED={ctrl}z
GREEN={ctrl}q
YELLOW={ctrl}x
BLUE={ctrl}c
TEXT={ctrl}{shift}t
TV={ctrl}t
TVNEW={ctrl}t
RADIO={ctrl}a
MUSIC={ctrl}m
VIDEOS={ctrl}e
PICTURES={ctrl}i
GUIDE={ctrl}g
CHNLPREV={ctrl}l
;Note: only tested with Windows Media Player 8
[Windows Media Player]
FULLSCREEN={alt}{enter}
BACK={esc}
MUTE={F8}
VOLUP={F10}
VOLDOWN={F9}
CHNLUP={VK_UP}
CHNLDOWN={VK_DN}
NAVUP={VK_UP}
NAVDOWN={VK_DN}
OK={enter}
REC=
STOP={ctrl}s
PAUSE={ctrl}p
PLAY={ctrl}p
REWIND={ctrl}b
FASTFWD={ctrl}f
SKIPFWD={ctrl}{shift}f
SKIPREV={ctrl}{shift}b
1={alt}1
2={alt}2
3={alt}3
YELLOW={ctrl}1
BLUE={ctrl}2
GRNPOWER={alt}{f4}
;Windows Media Player 8 Full Screen
; but "ActiveMovie Window" is terribly generic
[ActiveMovie Window]
BACK={esc}
MUTE={F8}
VOLUP={F10}
VOLDOWN={F9}
CHNLUP=
CHNLDOWN=
REC=
STOP={findwnd(,Windows Media Player)}{cmd(32809)}
PAUSE={findwnd(,Windows Media Player)}{cmd(32808)}
PLAY={findwnd(,Windows Media Player)}{cmd(32808)}
REWIND={findwnd(,Windows Media Player)}{cmd(32810)}
FASTFWD={findwnd(,Windows Media Player)}{cmd(32811)}
SKIPFWD={findwnd(,Windows Media Player)}{cmd(32812)}
SKIPREV={findwnd(,Windows Media Player)}{cmd(32813)}
1={alt}1
2={alt}2
3={alt}3
YELLOW={ctrl}1
BLUE={ctrl}2
GRNPOWER={alt}{f4}
[VTplus]
OLD0={ctrl}n0
0={ctrl}n0
1={ctrl}n1
2={ctrl}n2
3={ctrl}n3
4={ctrl}n4
5={ctrl}n5
6={ctrl}n6
7={ctrl}n7
8={ctrl}n8
9={ctrl}n9
OK={enter}
FULLSCREEN={alt}{space}x{alt}-x
CHNLUP={ctrl}{up}
VOLUP={ctrl}{F6}
VOLDOWN={ctrl}i
NAVUP={ctrl}{up}
NAVDOWN={ctrl}{down}
NAVLEFT={ctrl}i
NAVRIGHT={ctrl}{F6}
STOP={ctrl}s
RED={cmd(501)}
GREEN={cmd(502)}
YELLOW={cmd(503)}
BLUE={cmd(504)}
FULLSCREEN={alt}{space}r
; VTplus - new page dialog
[Create and Receive]
OLD0=0
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
OK={enter}
CHNLUP={shift}{tab}
CHNLDOWN={tab}
VOLDOWN={left}
VOLUP={right}
BACK={esc}
FULLSCREEN={space}
NAVUP={shift}{tab}
NAVDOWN={tab}
NAVLEFT={left}
NAVRIGHT={right}
[EPGdemo]
OK={enter}
VOLUP={tab}
BACK={BROWSER_BACK}
CHNLUP={shift}{tab}
CHNLDOWN={tab}
FULLSCREEN={enter}
NAVUP={shift}{tab}
NAVDOWN={tab}
NAVRIGHT={tab}
[Radio]
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
0=0
OLD0=0
MUTE=m
CHNLUP={f12}
CHNLDOWN={f11}
VOLUP={pgup}
VOLDOWN={pgdn}
MINIMIZE=n
RESERVED=r
FULLSCREEN=s
SOURCE={enter}
GRNPOWER={close(radio.exe)}
OK={enter}
; WinTV32 in fullscreen mode
[FullScreen]
OLD0=0
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=+
CHNLDOWN=-
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV={alt}{f4}
;RADIO={ctrl}t{sleep(100)}{alt}{f4}{sleep(750)}{run(radio.exe)}
MINIMIZE={alt}{space}n
SOURCE={ctrl}s
RESERVED={ctrl}t{alt}p{sleep(10000)}{ctrl}t
REC={ctrl}t{findwnd(wintv_32,wintv32)}{fgnwnd()}{cmd(3325)}
STOP={ctrl}f
PAUSE={ctrl}t{cmd(3319)}{sleep(3000)}{ctrl}t
PLAY={ctrl}t{cmd(3323)}
REWIND={cmd(32803)}
FASTFWD={cmd(32780}}
SKIPFWD={cmd(32775)}
SKIPREV={cmd(32879)}
BACK={ctrl}t
;hcwGo app guys may prefer this
GRNPOWER={ctrl}t
BLUE={space}
GREEN={ctrl}t{findwnd(wintv_32,wintv32)}{fgnwnd()}{cmd(3327)}{cmd(32847)}
;GREEN={ctrl}t{sleep(100)}{alt}{f4}{sleep(750)}{run(radio.exe)}
; DVB-t "now/next" feature
GUIDE={ctrl}i
FUNC={ctrl}i
;Live Mode - normal window
[WinTV32]
OLD0=0
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=+
CHNLDOWN=-
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV={alt}{f4}
RADIO={cmd(32847)}
;RADIO={alt}{f4}{sleep(750)}{run(radio.exe)}
SOURCE={ctrl}s
RESERVED={alt}p{sleep(3000)}
BLUE={space}
GRNPOWER={alt}{f4}
; CC on/off
YELLOW={cmd(32878)}
REC={cmd(3325)}{findwnd(wintv_32,wintv32)}{fgnwnd()}
STOP={ctrl}f
PAUSE={cmd(3319)}{sleep(1500)}{findwnd(wintv_32,wintv32)}{fgnwnd()}
PLAY={cmd(3323)}{findwnd(wintv_32,wintv32)}{fgnwnd()}
BACK={cmd(3327)}
;some interesting buttons for Live mode
; Toggle NoTitle mode
REWIND={cmd(32803)}
; Toggle TV mode
FASTFWD={ctrl}t
; Start/stop surfing
; last channel
CHNLPREV={cmd(32879)}
; CC on/off
SUBCC={cmd(32878)}
GUIDE={ctrl}i
FUNC={ctrl}i
TEXT={cmd(32884)}
;VCR Mode; recording
[WinTV32(1)]
OLD0=
0=
1=
2=
3=
4=
5=
6=
7=
8=
9=
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=
CHNLDOWN=
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV=
SOURCE=
RESERVED=
REC={cmd(3325)}
STOP={findwnd(wintv_32,wintv32)}{fgnwnd()}{cmd(3304)}
PAUSE={cmd(3301)}
PLAY=
REWIND=
FASTFWD=
SKIPFWD=
SKIPREV=
BACK={cmd(3327)}
GRNPOWER=
BLUE={space}
GREEN=
GUIDE={ctrl}i
FUNC={ctrl}i
;VCR Mode; playing
[WinTV32(2)]
OLD0={alt}y
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=
CHNLDOWN=
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV={alt}n
MINIMIZE={alt}s
SOURCE=
RESERVED={alt}q
REC={cmd(3325)}
PAUSE={cmd(3301)}
PLAY={cmd(3301)}
REWIND={cmd(3333)}
FASTFWD={cmd(3334)}
SKIPFWD={cmd(3305)}
SKIPREV={cmd(3306)}
BACK={cmd(3327)}
GRNPOWER={cmd(3327)}
BLUE={space}
GUIDE={ctrl}i
FUNC={ctrl}i
;VCR Mode; paused
[WinTV32(3)]
OLD0={alt}y
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=
CHNLDOWN=
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV={alt}n
MINIMIZE={alt}s
SOURCE=
RESERVED={alt}q
REC={cmd(3325)}
PAUSE={cmd(3301)}
PLAY={cmd(3301)}
REWIND={cmd(3333)}
FASTFWD={cmd(3334)}
SKIPFWD={cmd(3305)}
SKIPREV={cmd(3306)}
BACK={cmd(3327)}
BLUE={space}
GUIDE={ctrl}i
FUNC={ctrl}i
;VCR Mode; Live TV
[WinTV32(4)]
OLD0=0
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=+
CHNLDOWN=-
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV={alt}{f4}
SOURCE={ctrl}s
RESERVED={alt}p
REC={cmd(3325)}
STOP={cmd(3327)}
PLAY={cmd(3299)}
REWIND={cmd(3333)}
FASTFWD={cmd(3334)}
SKIPFWD={cmd(3305)}
SKIPREV={cmd(3306)}
BACK={cmd(3327)}
BLUE={space}
; CC on/off
YELLOW={cmd(32878)}
SUBCC={cmd(32878)}
GUIDE={ctrl}i
FUNC={ctrl}i
TEXT={cmd(32884)}
;Pause Mode; sliping or paused
[WinTV32(5)]
OLD0={alt}y
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=
CHNLDOWN=
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV={alt}n
MINIMIZE={alt}s
SOURCE=
RESERVED={alt}q
REC={cmd(3325)}
STOP={findwnd(wintv_32,wintv32)}{fgnwnd()}{cmd(3327)}
PAUSE={cmd(3301)}
PLAY={cmd(3299)}
REWIND={cmd(3333)}
FASTFWD={cmd(3334)}
SKIPFWD={cmd(3305)}
SKIPREV={cmd(3306)}
BACK={cmd(3327)}
BLUE={space}
GUIDE={ctrl}i
FUNC={ctrl}i
;Live Mode - FullScreen
; or VCR Mode, Live - Fullscreen
[WinTV32(8)]
OLD0=0
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=+
CHNLDOWN=-
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV={alt}{f4}
SOURCE={ctrl}s
STOP={ctrl}f
PAUSE={ctrl}t{findwnd(wintv_32,wintv32)}{cmd(3319)}{sleep(3000)}{ctrl}t
PLAY={ctrl}t{findwnd(wintv_32,wintv32)}{fgnwnd()}{cmd(3323)}
REWIND={ctrl}t{findwnd(wintv_32,wintv32)}{fgnwnd()}
FASTFWD=
SKIPFWD={findwnd(wintv_32,wintv32)}{cmd(32775)}
SKIPREV={findwnd(wintv_32,wintv32)}{cmd(32879)}
BACK={ctrl}t{findwnd(wintv_32,wintv32)}{fgnwnd()}
GRNPOWER={ctrl}t{findwnd(wintv_32,wintv32)}{fgnwnd()}
BLUE={space}
; CC on/off
YELLOW={findwnd(wintv_32,wintv32)}{cmd(32878)}
SUBCC={findwnd(wintv_32,wintv32)}{cmd(32878)}
CHNLPREV={findwnd(wintv_32,wintv32)}{cmd(32879)}
;GREEN={ctrl}t{findwnd(wintv_32,wintv32)}{sleep(100)}{alt}{f4}{sleep(750)}{run(radio.exe)}
GUIDE={ctrl}i
FUNC={ctrl}i
TEXT={findwnd(wintv_32,wintv32)}{cmd(32884)}
;Pause Mode, slipping, or paused Fullscreen
[WinTV32(9)]
OLD0={alt}y
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=
CHNLDOWN=
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV={ctrl}t{sleep(1000)}{alt}n{sleep(10000)}{ctrl}t
MINIMIZE={alt}s
SOURCE=
RESERVED={alt}q
STOP={ctrl}t{findwnd(wintv_32,wintv32)}{fgnwnd()}{cmd(3327)}
PAUSE={findwnd(wintv_32,wintv32)}{cmd(3301)}
PLAY={findwnd(wintv_32,wintv32)}{cmd(3299)}
REWIND={findwnd(wintv_32,wintv32)}{cmd(3333)}
FASTFWD={findwnd(wintv_32,wintv32)}{cmd(3334)}
SKIPFWD={findwnd(wintv_32,wintv32)}{cmd(3305)}
SKIPREV={findwnd(wintv_32,wintv32)}{cmd(3306)}
BLUE={space}
GUIDE={ctrl}i
FUNC={ctrl}i
;VCR Mode, Playing, Fullscreen
[WinTV32(10)]
OLD0={alt}y
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=
CHNLDOWN=
FULLSCREEN={ctrl}t{findwnd(wintv_32,wintv32)}{fgnwnd()}
TVNEW={ctrl}t{findwnd(wintv_32,wintv32)}{fgnwnd()}
TV={ctrl}t{sleep(1000)}{alt}n{sleep(3000)}{ctrl}t
MINIMIZE={alt}s
SOURCE=
RESERVED={cmd(3301)}
STOP={ctrl}t{findwnd(wintv_32,wintv32)}{fgnwnd()}{cmd(3304)}
PLAY={findwnd(wintv_32,wintv32)}{cmd(3301)}
BACK={ctrl}t
GRNPOWER={ctrl}t
BLUE={space}
GUIDE={ctrl}i
FUNC={ctrl}i
;VCR Mode, Paused, Fullscreen
[WinTV32(11)]
OLD0={alt}y
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=
CHNLDOWN=
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV={alt}{f4}
MINIMIZE={alt}s
SOURCE=
REC={ctrl}t{findwnd(wintv_32,wintv32)}{cmd(3325)}
STOP={ctrl}t{findwnd(wintv_32,wintv32)}{cmd(3327)}
BACK={ctrl}t
GRNPOWER={ctrl}t
BLUE={space}
GUIDE={ctrl}i
FUNC={ctrl}i
;VCR Mode; recording; Fullscreen
[WinTV32(12)]
OLD0=
0=
1=
2=
3=
4=
5=
6=
7=
8=
9=
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=
CHNLDOWN=
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV=
RADIO=
SOURCE=
RESERVED=
STOP={ctrl}t{findwnd(wintv_32,wintv32)}{cmd(3304)}
PLAY=
REWIND=
FASTFWD=
SKIPFWD=
SKIPREV=
BACK={ctrl}t
GRNPOWER={ctrl}t
BLUE={space}
GREEN=
GUIDE={ctrl}i
FUNC={ctrl}i
;full screen slip mode
[PVRFullScreen]
OLD0={alt}y
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=
CHNLDOWN=
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
MINIMIZE={alt}s
SOURCE=
RESERVED={alt}q
PLAY={ctrl}t{findwnd(wintv_32,wintv32)}{cmd(3299)}
BACK={ctrl}t{findwnd(wintv_32,wintv32)}{cmd(3327)}
GRNPOWER={ctrl}t
BLUE={space}
GUIDE={ctrl}i
FUNC={ctrl}i
; TV16 in a Window
[Win/TV]
OLD0=0
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=+
CHNLDOWN=-
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
TV={alt}{f4}
;Wintv16 Full Screen TV Mode
[Win/TV+]
OLD0=0
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
TV={alt}{f4}
MUTE={ctrl}m
VOLUP={pgup}
VOLDOWN={pgdn}
CHNLUP=+
CHNLDOWN=-
FULLSCREEN={ctrl}t
TVNEW={ctrl}t
SOURCE=
MINIMIZE=
; Special Macro Table for Task Switch Mode
[*task*]
OLD0=
0=
1=
2=
3=
4=
4=
5=
6=
7=
8=
9=
RADIO=
MUTE=
TV=
VOLUP={tab}
;RESERVED={esc}{^menu}{mode()}
CHNLUP=
CHNLDOWN=
SOURCE={^menu}{mode()}
MINIMIZE=
FULLSCREEN=
NAVUP=
NAVDOWN=
NAVRIGHT={tab}
GREEN={esc}{^menu}{mode()}
GRNPOWER={esc}{^menu}{mode()}
BACK={esc}{^menu}{mode()}
OK={^menu}{mode()}
; to use this, open notepad with a document name of debug.txt and set focus to it.
; debug.txt= must be uncommented in [applications] section as well.
[Debug.txt]
OLD0=OLD0{enter}
0=0{enter}
1=1{enter}
2=2{enter}
3=3{enter}
4=4{enter}
5=5{enter}
6=6{enter}
7=7{enter}
8=8{enter}
9=9{enter}
FULLSCREEN=FULLSCREEN{enter}
RADIO=RADIO{enter}
MUTE=MUTE{enter}
TV=TV{enter}
VOLUP=VOLUP{enter}
VOLDOWN=VOLDOWN{enter}
RESERVED=RESERVED{enter}
CHNLUP=CHNLUP{enter}
CHNLDOWN=CHNLDOWN{enter}
SOURCE=SOURCE{enter}
MINIMIZE=MINIMIZE{enter}
GREEN=GREEN{enter}
YELLOW=YELLOW{enter}
RED=RED{enter}
BLUE=BLUE{enter}
FUNC=FUNC{enter}
SKIPFWD=SKIPFWD{enter}
SKIPREV=SKIPREV{enter}
GRNPOWER=GRNPOWER{enter}
BACK=BACK{enter}
OK=OK{enter}
MENU=MENU{enter}
REC=REC{enter}
STOP=STOP{enter}
PAUSE=PAUSE{enter}
PLAY=PLAY{enter}
REWIND=REWIND{enter}
FASTFWD=FASTFWD{enter}
GO=GO{enter}
VIDEOS=VIDEOS{enter}
MUSIC=MUSIC{enter}
PICTURES=PICTURES{enter}
GUIDE=GUIDE{enter}
NAVLEFT=NAVLEFT{enter}
NAVRIGHT=NAVRIGHT{enter}
NAVUP=NAVUP{enter}
NAVDOWN=NAVDOWN{enter}
TEXT=TEXT{enter}
SUBCC=SUBCC{enter}
CHNLPREV=CHNLPREV{enter}
TVNEW=TVNEW{enter}
CODE0=CODE0{enter}
CODE1=CODE1{enter}
CODE2=CODE2{enter}
CODE3=CODE3{enter}
CODE4=CODE4{enter}
CODE5=CODE5{enter}
CODE6=CODE6{enter}
CODE7=CODE7{enter}
CODE8=CODE8{enter}
CODE9=CODE9{enter}
CODE10=CODE10{enter}
CODE11=CODE11{enter}
CODE12=CODE12{enter}
CODE13=CODE13{enter}
CODE14=CODE14{enter}
CODE15=CODE15{enter}
CODE16=CODE16{enter}
CODE17=CODE17{enter}
CODE18=CODE18{enter}
CODE19=CODE19{enter}
CODE20=CODE20{enter}
CODE21=CODE21{enter}
CODE22=CODE22{enter}
CODE23=CODE23{enter}
CODE24=CODE24{enter}
CODE25=CODE25{enter}
CODE26=CODE26{enter}
CODE27=CODE27{enter}
CODE28=CODE28{enter}
CODE29=CODE29{enter}
CODE30=CODE30{enter}
CODE31=CODE31{enter}
CODE32=CODE32{enter}
CODE33=CODE33{enter}
CODE34=CODE34{enter}
CODE35=CODE35{enter}
CODE36=CODE36{enter}
CODE37=CODE37{enter}
CODE38=CODE38{enter}
CODE39=CODE39{enter}
CODE40=CODE40{enter}
CODE41=CODE41{enter}
CODE42=CODE42{enter}
CODE43=CODE43{enter}
CODE44=CODE44{enter}
CODE45=CODE45{enter}
CODE46=CODE46{enter}
CODE47=CODE47{enter}
CODE48=CODE48{enter}
CODE49=CODE49{enter}
CODE50=CODE50{enter}
CODE51=CODE51{enter}
CODE52=CODE52{enter}
CODE53=CODE53{enter}
CODE54=CODE54{enter}
CODE55=CODE55{enter}
CODE56=CODE56{enter}
CODE57=CODE57{enter}
CODE58=CODE58{enter}
CODE59=CODE59{enter}
CODE60=CODE60{enter}
CODE61=CODE61{enter}
CODE62=CODE62{enter}
CODE63=CODE63{enter}
; TODO: Name to number mapping for sending APPCommands ; or general string replacement??
; for now, here is a list as reference
;[APPCommands]
;APPCOMMAND_BROWSER_BACKWARD       0x10000
;APPCOMMAND_BROWSER_FORWARD        0x20000
;APPCOMMAND_BROWSER_REFRESH        0x30000
;APPCOMMAND_BROWSER_STOP           0x40000
;APPCOMMAND_BROWSER_SEARCH         0x50000
;APPCOMMAND_BROWSER_FAVORITES      0x60000
;APPCOMMAND_BROWSER_HOME           0x70000
;APPCOMMAND_VOLUME_MUTE            0x80000
;APPCOMMAND_VOLUME_DOWN            0x90000
;APPCOMMAND_VOLUME_UP              0xa0000
;APPCOMMAND_MEDIA_NEXTTRACK        0xb0000
;APPCOMMAND_MEDIA_PREVIOUSTRACK    0xc0000
;APPCOMMAND_MEDIA_STOP             0xd0000
;APPCOMMAND_MEDIA_PLAY_PAUSE       0xe0000
;APPCOMMAND_LAUNCH_MAIL            0xf0000
;APPCOMMAND_LAUNCH_MEDIA_SELECT    0x100000
;APPCOMMAND_LAUNCH_APP1            0x110000
;APPCOMMAND_LAUNCH_APP2            0x120000
;APPCOMMAND_BASS_DOWN              0x130000
;APPCOMMAND_BASS_BOOST             0x140000
;APPCOMMAND_BASS_UP                0x150000
;APPCOMMAND_TREBLE_DOWN            0x160000
;APPCOMMAND_TREBLE_UP              0x170000
;APPCOMMAND_MICROPHONE_VOLUME_MUTE 0x180000
;APPCOMMAND_MICROPHONE_VOLUME_DOWN 0x190000
;APPCOMMAND_MICROPHONE_VOLUME_UP   0x1a0000
;APPCOMMAND_HELP                   0x1b0000
;APPCOMMAND_FIND                   0x1c0000
;APPCOMMAND_NEW                    0x1d0000
;APPCOMMAND_OPEN                   0x1e0000
;APPCOMMAND_CLOSE                  0x1f0000
;APPCOMMAND_SAVE                   0x200000
;APPCOMMAND_PRINT                  0x210000
;APPCOMMAND_UNDO                   0x220000
;APPCOMMAND_REDO                   0x230000
;APPCOMMAND_COPY                   0x240000
;APPCOMMAND_CUT                    0x250000
;APPCOMMAND_PASTE                  0x260000
;APPCOMMAND_REPLY_TO_MAIL          0x270000
;APPCOMMAND_FORWARD_MAIL           0x280000
;APPCOMMAND_SEND_MAIL              0x290000
;APPCOMMAND_SPELL_CHECK            0x2a0000
;APPCOMMAND_DICTATE_OR_COMMAND_CONTROL_TOGGLE    0x2b0000
;APPCOMMAND_MIC_ON_OFF_TOGGLE      0x2c0000
;APPCOMMAND_CORRECTION_LIST        0x2d0000
; new for WINXP SP1 - FREESTYLE
;APPCOMMAND_PLAY        0x2e0000
;APPCOMMAND_PAUSE       0x2f0000
;APPCOMMAND_RECORD      0x300000
;APPCOMMAND_FASTFORW    0x310000
;APPCOMMAND_FASTBACK    0x320000
;APPCOMMAND_CHAN_UP     0x330000
;APPCOMMAND_CHAN_DN     0x340000
; WinTV2000 Command IDs for PVR functions
; ID_STREAM_RECORD                3298
; ID_STREAM_SETUP_VCD             3330 (starts VCD recording)
; ID_STREAM_PLAY                  3299
; ID_STREAM_PAUSE                 3301
; ID_STREAM_STOP                  3304
; ID_STREAM_FF                    3305 (10 secs fwd)
; ID_STREAM_REWIND                3306 (10 secs back)
; ID_STREAM_EARLIEST              3307 (jump to start)
; ID_STREAM_LATEST                3308 (jump to end/near Live)
; ID_STREAM_PLAY_BACKWARDS        3333
; ID_STREAM_PLAY_FORWARD_FAST     3334
; ID_BUTTON_OTP                   3328 (Slip mode; don't pause)
; ID_STREAM_START_SLIP_MODE       3319 (Slip mode; start paused)
; ID_BUTTON_OTR                   3325 (start recording)
; ID_BUTTON_NORMAL_MODE           3327 (back to Live mode, close tray )
; ID_BUTTON_FILE_PLAY             3323 (the main app REC button, don't ask)
; ID_BUTTON_RADIO        32847 (launch Radio app/mode from WinTV)
; ID_BUTTON_VT           32884 (launch Teletext app/mode from WinTV)
so und die tatsten belegung is wie folgt in winamp:
 0=Stop mit Fadeout
 1=Display
 2=Play
 3=Stop
 4=Zurück
 5=Pause
 6=Schnell vorwärts
 7=Vergrössern
 8=Zufall
 9=Datei info box (RESERVED zum beenden)
 CHNLUP=Stueck weiter
 CHNLDOWN=Stueck zurueck
 VOLUP=lauter
 VOLDOWN=leiser
 RADIO=Winamp-beenden -> WinTv radio starten
 TV= WinTV-starten
 SOURCE=alt + tab
 MINIMIZE=Minimieren
 MUTE=Pause/Unpause
 FULLSCREEN=Start/Stop Visualisierung
 IrfanView
 0=Slideshow beenden
 1=Erstes Bild im Verzeichnis öffnen
 2=Hoch scrollen
 3=Bild an Bildschirm anpassen
 4=links scrollen
 5=Originalgrösse
 6=rechts scrollen
 7=Zufaelliges Bild
 8=runter-scrollen
 9=Letztes Bild im Verzeichnis öffnen
 CHNLUP=Nächstes Bild
 CHNLDOWN=Vorheriges Bild
 VOLUP=Vergrössern
 VOLDOWN=Verkleinern
 RADIO=IrfanView -> wintv radio starten
 TV=IrfanView -> WinTV-starten
 SOURCE=alt + tab
 MINIMIZE=Minimieren
 MUTE=Fenster minimieren
 FULLSCREEN=Slideshow mit den Bildern des aktuellen Verzeichnisse
folgen wird noch progdvb evtl nero und mal gucken was mir noch so einfält^^
